SailNet Community - View Single Post - Help with packing problem
post #9 of Old 08-12-2010
sailingdog
Yes, but on many boats, the stuffing box will drip very slowly when the shaft is not turning. If the stuffing box heats up noticeably when you're motoring, then it isn't being lubricated sufficiently—and you must adjust the stuffing box for when it is turning—and if it drips when the shaft isn't rotating, you just have to live with it.
Originally Posted by remetau View Post
Ours does not drip when the shaft is not turning.
This is from Don Casey:
"Water is required to lubricate conventional packing, so a properly adjusted stuffing box can be watertight when the shaft is stopped, but it must drip when the shaft is turning."
sailingdog is offline
