SailNet Community - View Single Post - stuck keel
Thread: stuck keel
post #8 of Old 08-12-2010
Boasun
Boasun's Avatar
On the steel Center board. Have the boat on the hard and drop it out and determine if it is salvagable or not. If it is, clean the rust off, pickle the steel then primer and paint it with bottom paint.
On the swollen wood of the CB Well you need to let it dry out then primer & paint it with bottom paint.
But while the CB is out, you can check for dry rot and other ills that may affect the wood structure of your CB well and keel.
Check the pivot pin for wear and the babbit bearing also. Along with the connection point of your CB Pendant.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
