SailNet Community - View Single Post - Refitting Interiors
post #23 of Old 08-15-2010
puddinlegs
Originally Posted by blt2ski View Post
puddinglegs
Yes everything is ran to a clutch vs a cam cleat or equal. I personally found teh spinlocks I am using to be the better/best bang for the buck, and makes sure things stay locked in place. The only real issue I have, is the ones for the main and jib I use the most, seem to be starting to slip, so not sure if it is inside the mechanism, and need to get a recam kit and fix, or go to the next higher lb ability clutch for those high lb/strength needed items.
I mostly sail out of edmonds, will be at shilshoal for the styc fall/winter ragatta in Oct. Boat will probably sail in FWB, I'll be on RC as PRO.
Marty
Sorry everyone for the small hijack...
Yeah, doesn't seem like there's a clutch made that will hold a main or jib halyard well over time. Have this problem on our boat and another boat I sail on regularly. On the other boat, we're thinking about using two clutches in line on the jib halyard. Maybe we'll see you out at the styc fall race day!
puddinlegs is offline
