SailNet Community - View Single Post - Simple electrical system question
post #8 of Old 08-15-2010
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
As long as your outboard has a pull start (likely on a little Catalina), that scheme would be fine. However, if you need battery power to get the motor started, you really should have a second battery that can be kept independent (or semi-independent). There's nothing quite like really needing the motor to start, hitting the start button, and hearing little more than a "click-click-click", if that.
SlowButSteady is offline
