SailNet Community - View Single Post - Cal-29 shower
Thread: Cal-29 shower
post #8 of Old 08-17-2010
I also have a '74 Cal 2-29. The ice box is on the starboard side. Fresh water intake for the head is on the port side under bench at the bulkhead. The 2-29 has a large drain hole in the aft edge of the floor pan (1" diameter). You should be able to get a pipe brush in there to clear any debris, otherwise it should drain into the bilge without a problem.
JamieVT is offline
