SailNet Community - View Single Post - rebedding stanchion
post #5 of Old 08-20-2010
jbondy
Senior Mumble
jbondy's Avatar
If the 303 is like my 323, the hull-to-deck joint is based on an inward flange. The deck is cored, but not all the way to the edge where its thickness tapers, so some of the holes are thru deck that is not cored. Some holes pass thru core on the border between cored and uncored deck, so you have to seal anyway. Just don't expect to be able to dig out core material on all sides of some holes. Let's just say that the bent nail or sharpened hex key technique doesn't work so well with some of these holes. I learned that a 1/2 HP drill can generate enough force to rip itself out of your hands. It's too bad Pearson couldn't make that thinner part of the deck wide enough for the stanchion bases to go over uncored deck!
jbondy is offline
