SailNet Community - View Single Post - How do you affix your anchor sail to your backstay?
post #4 of Old 08-22-2010 Thread Starter
Bene505
Glad I found Sailnet
Bene505's Avatar
Thanks Faster, I'll have to look into the plastic hanks.
Originally Posted by CapTim View Post
Well, maybe it's not 'racey' or something.. and I would certainly use proper small stuff.. but your technique there should work just fine. Maybe a couple of vertical turns between the sail and the stay, just to keep plenty of tension in the system (will help keep the sail from sliding up/down the stay, as well as keep the knot from shaking out).
I don't know.. I mean, spend money if you want. But that will work fine (though the choice of small stuff is not something to ignore.. what are you using now?)
Yes, that was some scrap line I had, and one of the reasons I took the anchor sail down tonight.
I have some 1/4 inch dacron that I'm using for the upper eye. I need to get something as robust for the lower eye.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
