SailNet Community - View Single Post - Yanmar engine mounts keep failing 3JH4E
post #2 of Old 08-23-2010
pedcab
pedcab's Avatar
Originally Posted by flyingfishUK View Post
We have a beneteau 40.7 with a Yanmar 3HJ4E engine. Since November last year we have had 3 sets of engine mounts fail with no obvious cause. We replace the mounts then about a month later they snap again! A local marine engineering company have removed the engine and gearbox, checked alignment then refitted. We have just had another set of mounts fail again! We have contacted Yanmar but they have never heard of this fault... emm
The engine runs perfectly in neutral, forward and reverse
The engine mounts are the standard set fitted to all engines of this type
Has anybody had this problem before?
Andy
I've heard about that problem a few times and the causes were found to be one or more of the following:
1- Shaft alignment issues
2- Shaft length issues (too long shafts)
3- Outside shaft support alignment/ sturdyness
3- Propeller balance
Pedro
Portugal
pedcab is offline
