SailNet Community - View Single Post - stuffing box repacking and flax size
post #2 of Old 08-23-2010
Gene T
Gene T's Avatar
Don't worry about sinking the boat. If you have an automatic bilge pump it will only run every few minutes. There really isn't much water that comes in around the shaft. I would unscrew the nut and measure the packing, then snug up the nut again and go buy the packing. Probably 1/4 but possible 3/16.
A small hook is handy for pulling the old packing but a small screwdriver works. The also sell a puller that screws into the packing and makes it easy. You could pull one piece out to get the correct size. It should still seal up good enough for a while with what is left.
I always had good luck with Teflon Flax. Read up a bit on how to do it. 3 pieces are generally used offsetting the cuts. I always liked to snug it up good and then back it off until it would drip a little. (not much dripping needed). Check the alignment while you are down there too.
Gene
Currently in Long Beach, CA
Gene T is offline
