SailNet Community - View Single Post - rpms quiz
Thread: rpms quiz
post #3 of Old 08-25-2010
sailingdog
When you were working on the engine, did you replace the crush washers on the fuel line banjo bolts? If not, they're likely to be a possible cause of intermittent air leaks. The crush washers are not designed to be re-used, and if re-used may not seal properly.
sailingdog is offline
