SailNet Community - View Single Post - Raymarine Pathfinder and DSC data
post #3 of Old 08-27-2010
sailingdog
Does the Raymarine GPS have NMEA 0183 output? If so, then wiring it should be relatively easy. You need to check the manual for the Raymarine Pathfinder and see what outputs it has, and what version of NMEA 0183, if any, it has. Be aware that if the Pathfinder does output an older version of NMEA 0183, it may not be compatible with the iCom, which may require a newer version.
sailingdog is offline
