SailNet Community - View Single Post - 2QM15 in Cherubini Hunter 27, anyone done it?
post #2 of Old 08-28-2010
I have a 2qm15 in a Crown 34, disp ~10,500 lbs. We run a 14X8 2-blade. I can't speak with authority but likely the final drive is 2.14:1. I think your 13X8 prop should be in the ballpark. Have you done a prop calc using something like:Vicprop - Prop calculator for Displacement and semi-displacement hulls
Using rough numbers from
it calculatex a 14X8 prop
Not sure if that helps
davidr8 is offline
