SailNet Community - View Single Post - Drilling Hole in Fiberglass Hull
post #5 of Old 08-29-2010
sailingdog
If you run the hole saw in reverse until you get through the gelcoat, you'll cut the gelcoat without much chipping. Taping the area with masking tape will help too.
If the hull is cored where you install the through-hull, you'll want to remove some of the core and pot the hole with thickened epoxy before installing the through-hull.
Also, don't put through-hulls too close to each other. Doing so can weaken the hull and lead to failure. Back the through-hull with a fiberglass backing block bedded in thickened epoxy.
sailingdog is offline
