SailNet Community - View Single Post - Diesel exhaust- water?
post #4 of Old 06-12-2006
duffer1960
Catalina 38 Avantura
duffer1960's Avatar
Is the raw water seacock open? Is your impeller ok? I would check these two ASAP. If this is a new to you boat, and it is the first time in the water this season, the seacock may be closed and/or the impeller removed for winterization. ALso, before you open that seacock, make sure it's hose is clamped on securely.
Sincerely,
Russ Duff
Catalina 38, Hull #112
"AVANTURA"
Lake Erie
Grosse Ile, Michigan
duffer1960 is offline
