SailNet Community - View Single Post - Diesel exhaust- water?
post #7 of Old 06-12-2006
If you ran the engine for 20 min with no overheat your impellar is fine assuming your temp gage is accurate. If the impellar had failed you would go to overheat in a matter of minutes. The impellar should be replaced every 100 hours...50 hours if you want to be safe.
Cat400 is offline
