SailNet Community - View Single Post - Runaway Diesel.. or not?
post #2 of Old 06-12-2006
hellosailor
John, how is your oil level? If the lift pump leaks, fuel can be pumped into the oil, resulting in the oil level coming up too high, and some engines will then start to ingest oil and run away, because as far as they are concerned it is "more fuel" and they really don't care about where it is coming from.
If your oil level has been going UP instead of down, or the oil feels thin and slick (from the fuel)...that can do it.
It might be getting too much from some kind of injector/pump failure I guess, but I'd check the simplest thing (oil level) first.
hellosailor is offline
