SailNet Community - View Single Post - Runaway Diesel.. or not?
post #10 of Old 06-13-2006
DeepFrz
Probably not your problem, however I heard of one guy had his tanks cleaned and the workman left a rag in one of the tanks.
I had a partially plugged fuel line once and the engine would run for minutes before dying. Start up a few minutes later and it would run for a while and die. It all depends on how much fuel is getting by the obstruction. After blowing the line with a scuba tank I ran a wire through the line and then pulled some small pieces of cloth through to get all the gunk. This happened in the Yucatan Straights. ugh...
good luck
Deep
DeepFrz is offline
