Old 06-13-2006
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
Another place that the deck commonly delaminates is around the chainplates. I would recommend checking the area around the chainplates fairly thouroughly.
Also, if the mast is deck-stepped, then look in the cabin, and check to see if the cabin roof is sagging or not. If it is, regardless of whether there is a compression post, you will need some work. In some cases, the compression post isn't properly aligned with the mast foot, so the mast foot transfers loads to the cabin roof and causes a sag.
If you're new to the Sailnet Forums... please read this POST.
