If you have access to the top of the mast, via a lift or a crane, then it really isn't much of a deal. You can generally use your spinnaker or genoa halyard to hold the mast in place, while you swap out the forestay. Provided you have access, you could do this relatively easily yourself. If not, most riggers will do this for a fairly reasonable fee.
Saying what region your boat is in would probably lead to more suggestions for riggers in your area.
