SailNet Community - View Single Post - Challenging ASA ratings?
post #4 of Old 09-04-2010
tempest
Hi Jordan,
For the sailing certifications:
There are two Parts to obtaining an ASA certification. Part one: is knowedge
( written test ) Part two: is the on-water demonstration of skills in an appropriate vessel.
Just to clarify...
Are you saying that you found an ASA school that will grant you those certifications by only taking the written tests? Or, will you also be asked to demonstrate the on-water skills as part of your challenge?
Keep in mind, that if you are challenging the skills portion, it's not a course.
there's no instructional piece to it. You will need to demonstrate all the skills correctly without the aid of instruction.
The bareboat charter, has a 48 hour component to it, as well. How will that be handled? Can you document, time served aboard other vessels of appropriate size as master or mate ?
To answer your question: The standards listed basically cover the knowledge you need to pass the written tests. In addition, you should know how a diesel engine works.
The navigation is a test only. Some mistakes can be cumulative. Meaning, there are multi part questions regarding a single plot. ie. If you navigate to the wrong place on a chart....you will also get the depth wrong and the type of bottom etc. The 1st 5 questions are fill-ins...chart symbols. It's not an easy test.
Good luck.
tempest is offline
