IIRC, the taffeta material was primarily there for UV protection of the underlying laminate. If you remove it, the sail will degrade much faster than it would with it in place. Why do you think the taffeta material can not be re-bonded??
Calling a North sails loft for advice might be a wise idea. They've probably run into this issue previously.
