SailNet Community - View Single Post - Suddenly buring oil?
post #3 of Old 09-14-2010
Maine Sail
Maine Sail's Avatar
What is max rated RPM of the Vetus. You should be able to hit max rated RPM at wide open throttle with a clean bottom and prop. You'll ideally want to be within 100 RPM of max rated. If the engine is rated at 3600 RPM you are simply over pitched. If max rated is 3000 RPM then you are spot on.
______
-Maine Sail / CS-36T
Maine Sail is offline
