That wire definitely will be the expensive part no doubt. I've already got the DCP and ACR. My last question (ok for the moment). My batteries (3 8D AGMs) are each 245 AH (1725 MCA and 1350 CCA). The alternator is 80 amps (went to the boat to check) and battery charger is 40 amps max. With the diagram from sailingdog (I've decided on basically his configuration), what size fuses and what ampherage bus bars should I use? Wire gauges will have to wait until I see how long each run is. Again, I appreciate all the help.
