Epoxy-based paints are often used as osmosis barrier coats on sailboats, so an epoxy-based paint should provide relatively good protection to the fiberglass from water intrusion.
As to whether it will prevent your fiberglass repair from leaking...not necessarily. If you've botched the repair, no amount of paint will make it water tight.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
