SailNet Community - View Single Post - Blistering
Thread: Blistering
post #2 of Old 06-20-2006
sailingdog
Depends on how deep the blisters go. If they are mostly superficial, and in the gelcoat, then sanding, letting the hull dry and then re-fair and epoxy barrier coating is probably the way to go. If the blisters go deeper into the laminate, then you'll have a lot of nasty work cut out for you...not that blisters aren't nasty to begin with.
sailingdog is offline
