SailNet Community - View Single Post - Stuck centerboard
post #7 of Old 09-28-2010
CalebD
Tartan 27' owner
CalebD's Avatar
Do we even know what type and make of boat this is with the stuck center board?
I like the idea of using the low E string of a guitar to help clear the slot in the center board trunk though. Barring that a flat piece of metal might dislodge the offending high spots; something like an old metal yard stick.
If that fails then motoring around on the bay when there is some chop might just induce the board to become un-stuck. Make sure to loosen the pennant a little bit before motoring into the waves. You will know when it falls and if it doesn't then you have not lost anything, or you were not motoring in rough enough conditions to get it loose.
What kind of boat weighs 2000#'s that has a center board? Is this a MacGregor 26 or a Hunter 260 (extra zero added for emphasis)?
The board will go down again with the right encouragement.
Everybody has one:
CalebD is offline
