Do you have the throttle wide open when you crack the
lines at each injector? A long shot that the injection
pump would suddenly quit completely. Assume you don't mean the low pressure (lift)
pump and are getting
fuel out of the other bleed connections.
Injection
pump rebuild is not cheap. Must be done by a qualified diesel injection shop, not a diesel mechanic.
