Originally Posted by WanderingFool
After a time sitting my engine quit abruptly underway. Spent 30 hours sailing 40 miles in 0 - light wind. I bled the engine numerous times and changed all filters. HOWEVER. When I crack the fuel line to the injectors no fuel comes out. After much reading and my limited knowledge of engines I have concluded the injector pump is not pumping. Does this sound correct? If so I am wondering if anyone has gotten their injector pump rebuilt and wondering the cost and if it's fairly easy to take the pump off myself. I'm out cruising now and have limited time to be engineless without great hardship. Any help would be greatly appreciated.
Thank you.
The above advice is all spot on, but I thought I'd chuck this in: How much
fuel are you expecting to come out when you say "crack the
fuel line"??
Try this first:
1. Disconnect the fuel
lines at the injectors
completely. Cap off the injectors so you don't get anything in them.
2. Put a clean rag under the ends to catch any fuel that comes out.
3. Have someone crank the engine - for several seconds. You should see
tiny spurts of fuel out the end of each fuel
line.
Cheers,
Cameron
