It sounds like the transfer pump quit. (I'm a diesel/hvy. equip. mech.)
a quick search on your motor says you have an electric fuel pump (if it's after 1986) feeding the injection pump. check that 1st. A small universal fit "Bendix tic tic type" electric fuel pump would replace it if you can't get a direct replacement pump.
If you don't have an elec. pump feeding it then it's probably a diaphragm type pump (like an older car fuel pump) and can be rebuilt by you if you have basic mech. skills. simply a few screws/bolts and replace a few diaphragms.
cleanliness is important when working around open fuel lines.
Universal Diesel Engine Owners Manual - Fuel System - Marine Diesel Direct / Torresen Sailing Site
p.s. you only get tiny drops of fuel out of the cracked lines, it doesn't gush out.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
