SailNet Community - View Single Post - Heave to, WTH?
Thread: Heave to, WTH?
post #7 of Old 10-04-2010
PalmettoSailor
Originally Posted by jslade8581 View Post
I think the confusion is based on two things:
1. The technique of heaving-to. Most of us probably got the basic concept as a set of instructions (tack the boat through the wind without shifting the jib, letting it back, then lash the tiller to leeward or towards the mainsail). But heaving-to is defined as "using any sail combination, any gear combination necessary to get your boat to lie stopped, about 50 degrees from the wind and drifting slowly, directly away from the wind behind its own slick" (Storm Tactics, Pardey and Pardey, p. 13). The method that the video narrator describes is his method of heaving-to.
2. The concept of the slick. Again, based on Storm Tactics, the slick breaks up waves in bad gales, which will help protect the boat. In fact, Storm Tactics is pretty much a dissertation on how and why you should heave-to in gales vice running, lying a-hull, or any other basic storm method. They made a believer out of me.
Annnnnd this post just became an advertisement for Storms Tactics. Here's a link to it: Amazon.com.
Yeah, that.
Heaving to in 15 knots to have a relaxing lunch in the cockpit is a different animal from heaving to to spare wear and tear on the boat and crew in storm conditions.
There is no way your jib would survive being bashed against the speaders in 30-40 knots for hours. I personally wouldn't want the jib up if were heaving to even in as little as 20 knots of wind. Even in the winds I typically sail in, I roll in some jib before heaving to to keep the jib from touching anything.
I haven't yet practiced heaving to with main only in heavier winds but its something I would like to try, as it seems a good strategy if the forecast is off and things start to get out of hand.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
