Old 10-04-2010
paulh7859 paulh7859 is offline
paulh7859 is on a distinguished road
I hear the hull can leak water through the dagger board slots. To test should be able to (a) presurize air into a drain plug hole and see if air pressure holds, or (b) empty all water in hull, insert drain plugs, check if any new water gets into hull.
