SailNet Community - View Single Post - Bedding Deck Hardware With Butyl Tape
post #44 of Old 10-09-2010
CapnRon47
sealing around mounted wood toerail
I am refinishing the teak toerails, their attachment to the deck is fine and there are no leaks. However, the current sealant (unknown) has dried and breaks away from the teak (and deck) along the joint between the teak and the gelcoat as I scrape it. I do not intend to remove and rebed the toerail. What would you recommend I use to reform a bead along the joint between the teak and the deck?
Thanks,
CapnRon47 is offline
