SailNet Community - View Single Post - Mast leaks on keel stepped 52' mast
post #3 of Old 06-25-2006
sailingdog
I'd agree with Faster... if you've got internal wiring and halyards on the mast, rain water will find its way in, no matter what you do. The only real way to prevent water from coming down through the mast is to insert a plug or floor in the mast, above the deck partners, and have drainage of some sort.
My friend built a conical plug that sits inside his mast and has holes drilled through it for the wiring to pass through. It has a single drain hose attached to the bottom of the cone, and that leads to a hose that drains out side the mast. Not a bad solution but was a pain to make and install.
sailingdog is offline
