SailNet Community - View Single Post - Long Range WiFi -- Posting right now using "long range" wireless
post #23 of Old 10-13-2010
DropTop
DropTop's Avatar
At longer distance, the vertical beam angle is less of an issue. It is really only at shorter distances that it is a significant issue. The further you are from the WiFi hotspot, the more height the vertical beam angle will cover.
correct, but the closer you are the stronger the signal will be, and the more signal reflection you will have, so you will still have a useable signal, even if each side's antenna is not in the focused part of the beam. Plus the beam widths are not hard edges, look at a antenna RF radiation patterns in the specs and you will see that there are significant amounts of RF energy being pumped out in other directions beyond the advertised beamwidth. look at page 2 of the PDF linked below for an example.
http://www.streakwave.com/mmSWAVE1/Video/Pawod24-v2.pdf
Four Points - 1990 Hunter 27'
DropTop is offline
