SailNet Community - View Single Post - refrigeration
Thread: refrigeration
Old 06-26-2006   #3
camaraderie
moderate?
camaraderie's Avatar
In a properly insulated small box, any of the small systems can keep your stuff cool for less than 50 amps a day...which means a hundred amps of planned battery capacity. If you have this to spare or can add it, then you should be OK with any of the major systems. Having owned a system which was either air or water cooled, I found no difference in amp usage,,,the water cooling ran less but used more amps while running due to the pump. The air cooling ran a lot but at 5 amps less draw. The main thing I think on a new installation is to make sure your box is very well insulated. Good luck!
camaraderie is offline   Reply With Quote Share with Facebook
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
