SailNet Community - View Single Post - head troubles......
post #16 of Old 10-13-2010
sailingdog
T37Chef—
The twist-lock mechanism is a hackneyed way of solving a non-issue in a better designed head. The Raritan PHC LBA unit is only $220, and not the same thing as the pump you've pointed out. The Jabsco head you're pointing out is $175. For the $45 price difference, I'd recycle the bowl and get the Raritan instead.
A brand-new Raritan PHC head unit is $454...so for $220, you're getting the equivalent of a $455 head that is probably one of the best designed in the business and recommended by Peggie Hall....BTW, the RARITAN Compact II you linked to is not the same thing or in the same league as the PHC/PHII... totally different beasties.
Originally Posted by T37Chef View Post
The Raritain is about the same price? When I looked they were almost double the Jabsco? And what makes the Jabsco unit "louzy"...Ive had mine for about three years and it works just fine, probably will need to rebuild it in a year or two but just about any head will need that, no?
No sure how accurate these comparative prices are for the Raritan but...
Raritan PHII and PHEII Marine Toilets and Accessories RAR-PHII Standard 12V Toilet: Compare Prices, View Price History and Read Reviews at NexTag
Edit: From Defender
Jabsco New Twist 'n' Lock Manual Marine Toilet
Raritan Compact II Manual Toilet
For another $130 +- the Raritan is most likely the better buy, of course you could just buy the coversion kit as SD mentions, PHII Pump Assembly
sailingdog is offline
