SailNet Community - View Single Post - Yanmar 3YM30 in a PS 31 cruising RPM
post #4 of Old 10-14-2010
stevemac00
I have 3gm with the maxprop. I can hit around 3400-3600. I just talked to Larry Berlin at Mac Boring and he said you should run at max a few hours each month to burn off the varnish. he also said the tachs are notoriously inaccurate and you should have a handheld to calibrate at different rpms.
I usually run mine around 2700 as that provides me with the best speed/efficiency ratio. For me that's a little over 5 kits and burning a little over a half gallon/hr. But I'm always loaded down into the water line stripe. If I take it up to 3200, it's a lot louder and burns a lot more fuel for marginally faster speed. I do run it high once a while as recommended.
Forgot to add, your dealer is wrong. The maximum rpm is for the engine - not a prop/engine combination.
Steve
PSC 31 #84
Talisman
stevemac00 is offline
