SailNet Community - View Single Post - How hard/$$$ to replace furling main with a proper battened one?
post #5 of Old 10-15-2010 Thread Starter
Man Overboard
Is the main an in-mast furling main? If so, you may need to replace the spar or modify it. Replacing it would reduce weight aloft, since you won't have the furling gear in the mast anymore.
It is, alas. And by replacing the spar you do mean the whole mast needs to be remade, with spreaders, etc?
Is there somewhere I can check the cost (and once I am at it, for a proper rotating mast cost?)
EarthBM is offline
