SailNet Community - View Single Post - How hard/$$$ to replace furling main with a proper battened one?
post #7 of Old 10-15-2010
sailingdog
Well, you could move the a lot of the hardware over from the existing mast, but it would be a lot of work and unless you did it yourself, it would probably be more expensive than buying the entire mast.
You'll probably have to replace the rigging too—and given the age of the boat, that might not be a bad idea.
Originally Posted by EarthBM View Post
It is, alas. And by replacing the spar you do mean the whole mast needs to be remade, with spreaders, etc?
Is there somewhere I can check the cost (and once I am at it, for a proper rotating mast cost?)
sailingdog is offline
