SailNet Community - View Single Post - Yanmar 3gmd Max RPM
Old 10-18-2010
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
Originally Posted by casey1999 View Post
I have not tried to go to max rpm at in neutral. Could I damage the engine by going to max rpm with no load?
There is no problem revving the engine in neutral. I think most of us assumed the rpms you were reporting were in neutral.
If it revs right up to 3200-3400 in neutral (I suspect it will), you have all the signs/symptoms of being over-propped. That is not good for the engine, so you should change it even if somebody else went around the world like that.
