SailNet Community - View Single Post - thru-hull electric connector - at least 13 pins
post #2 of Old 06-28-2006
sailingdog
Why not do two nine-pin connectors, that would leave you some room for expansion.
You might be far better off putting the actual instruments inside the boat and using repeater displays on the exterior of the boat. Then you would only need to run a single three-wire SeaTalk cable through the deck. Much simpler...and easier. Wiring the panel will also be much easier.
Also, if someone nicks your external panel, you'll still have the original instruments inside the boat to use.
sailingdog is offline
