SailNet Community - View Single Post - Handy tip for storing 3M 5200, etc...
post #1 of Old 10-25-2010 Thread Starter
SoulVoyage
seeker of wonder
SoulVoyage's Avatar
I've always had a problem with the remaining 5200, etc in the tube going dry before the next time I used it. I tried taping the end, plugging it with a screw, etc...all with the same results...dried 5200 in a tube.
Here's a trick I've since learned that works GREAT!!!:
Next time, leave a little bit of the 5200 out of the tube somewhere, doesn't take much, and after recapping the tube, put a good bead of 5200 around the cap of the tube and leave to dry in a safe place before putting the tube away.
Yes...you have to use pliers to remove the cap, but since it's an aluminum tube and a plastic cap...it removes just fine.
I just tried it on my first tube...left it for a two months, and after removing the cap...the 5200 was like brand-new underneath (and we're talking the Fast Cure stuff!!!). It works equally well with the small tubes and the cartridge tubes. I'm sure I'm not the only one who's had problems with dried adhesive in a tube.
"...and a star to steer her by."
SoulVoyage is offline
