SailNet Community - View Single Post - Anchorages and Moorings in Key West
post #2 of Old 10-25-2010
cmendoza
cmendoza's Avatar
Didn't record lat/long, but you should be able to find these on your charts with little trouble... first, you obviously need to use Hawk Channel to travel, second, please double check everything, because, well, because you should ;-)
You're definitely pushing it just about everywhere, but here are the stops we made on our way to Key West from Ft. Lauderdale:
Key Biscayne (No Name Harbor)
Should be OK... 7-10 ft.
Rodriguez Key (eastern side on the way down, western side on the way back)
Same, 7-10 ft. give or take
Marathon
We couldn't get into boot key harbor because of mast hight, so can't say, but stayed at Burdines Marina... entrance channel was tight, so be careful...
Key West
Stayed in the mooring field on the eastern side of Fleming Key
Again, 7-10 ft. or so...
Hope it helps,
Carlos & Maria
S/V Rocinante
Carlos & Maria
...you may not be able to control the wind,
but you can adjust your sails..._/)
cmendoza is offline
