SailNet Community - View Single Post - Yanmar 3GMD transmission oil confusion in manuals
post #9 of Old 10-25-2010 Thread Starter
mbsl98
Just a quick update. I found the ID plate on the Kz transmission with my 3GMD. As best as I can read it upside down and through the touch up paint, it calls for use of .3 liters of 20/30 weight oil. Since there has never been a multi-weight 20/30 that I know of, I assume that this means it should have either 20 or 30 weight engine oil. I understand that Yanmar has updated the original engine oil spec form the old 30/40 to a multi-weight 15-40, so i don't know if there is an update to the tranny oil spec as well. In any case, it is clear that the manual references to ATF are not correct.
mbsl98 is offline
