SailNet Community - View Single Post - Fuse size for fuse panel?
post #8 of Old 10-25-2010
sailingdog
If there's an electrical fire near the batteries... you really don't want to have to reach over them to shut them off...since you'll give the fire a lot more oxygen...
You really want to strap the batteries down or install a wooden bar to hold them down. You really should put covers on the positive terminals, if not both sets.
It would also make a lot more sense to have the battery cables go to the bus bars in a different area of the boat and have the fuse panel and switch located there. It would make it a lot easier to work on them and not risk accidentally shorting the batteries.
BTW, the ATO/ATC fuses go up to 40 amps, not 30.
sailingdog is offline
