SailNet Community - View Single Post - We are 99% sure we are going engine-less
post #6 of Old 10-26-2010
sailingdog
Originally Posted by chrisncate View Post
We should be able to use the o/b for all you listed above though, right (the Panama canal, tough marinas, etc)?
It would be tough to use for the Panama Canal, as it probably isn't going to be powerful enough to drive the boat at the speeds they canal authority require. Also, in situations where the seas are heavier or there are wakes from other boats to contend with, the prop will probably ventilate a lot more than you'd want.
On the modern marina/tight fairway note, I have to tell you our current marina is notorious for this. They have crammed more slips into that place than you could believe as it is a condo/slip owner marina... it's tight in that place and we are used to that at this point..
Yup... they do that to maximize the money they can make.
sailingdog is offline
