SailNet Community - View Single Post - Morgan 30/2, C&C 30, Newport 30 Mark III
post #27 of Old 10-27-2010
msmith10
Junior member, rest old
msmith10's Avatar
That's too bad about the C&C, but good that you found problem with the Morgan before you bought it. Don't worry- good used boats are anything but scarce. Also, you were able to eliminate the Morgan before spending money on a survey. Once you've decided a boat passes your inspection, then find a surveyor to look it over. If the survey indicates a passable boat, it will often find enough problems (problems that you may be willing to accept) to negotiate the purchase price down enough to cover the cost of the survey.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
