SailNet Community - View Single Post - recoring help needed
post #2 of Old 10-28-2010
amarinesurveyor
In your first sentence you missed the thickness (you had 3/), I'm not sure whether it is 3/8 or 3/4. As long as the thickness of the core is the same, it shouldn't matter a whole lot, what material you use, as long as the laminate thickness on top of it is the same as the surrounding areas. Is it a high stress area like under a windlass or were all of the decks core with plywood? Make sure you seal up all deck penetrations where the water may have entered.
Brian
amarinesurveyor is offline
