SailNet Community - View Single Post - recoring help needed
post #6 of Old 10-28-2010
tommays
tommays's Avatar
There are no small wet spots in plywood you may be able to live with wet in some areas BUT
What boat you are repairing is a factor as someone who has owned a J24 were the inner and out skins merge into a very solid single piece at the hull deck joint and above deck repair is no problem
On my plywood core Cal 29 all the good advise in the world will not make up for the fact that the inner skin on the Cal is just sealed to the core and while it is important in keeping the core sandwich stiff
It will come out with the plywood leaving a big hole in the boat
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
