BR—
I've got pretty
good instructions for XP users on my blog.
A flag halyard would work nicely, but I'd add a
line from the antenna to the cable, so that the wire's weight is supported by the
line rather than the RJ45 data jack in the base of the Bullet.
What you'll need:
Bullet 2HP or M2HP
9 dB gain fiberglass antenna with N-Female connector on the base
A long ethernet cable, preferably tinned stranded wire, like Belden 1702A wire.
A 12 VDC POE injector
A short ethernet cable, again preferably tinned stranded wire, like Belden 1702A wire.
If you've got questions, give me a shout.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
